What is everyone out there with high HP numbers using for clutch set-ups?
1MEANSNAKE
Prince Frederick Maryland, On the Chesapeake Bay
What is everyone out there with high HP numbers using for clutch set-ups? Im at the point where i need to replace the clutch from the added boost and need to know what you guys are using.
I'd like to keep the streetability of the OEM clutch with pedal feel and absoulutely no chattering if possible.
Any info would be beneficial, thanks in advance.
PS Im considering the McLeod twin disc set-up and flywheel, thoughts???
Also posted over at the alley
Joseph Dell
Atlanta, GA 30338
Re: What is everyone out there with high HP numbers using for clutch set-up
Spec 3 has been good for me, but i haven't tried drag racing w/ it and the 1400rwhp yet. now sure about cost on the McLeod. how much does that run?
PS - check your PM. I know you got the last one... Let's put this to bed sooner than later.
JD
1MEANSNAKE
1MEANSNAKE
JD, sent you a PM back, sorry we dont get PM notices like we should for some reason. The McLeod twin disc with flywheel is $2k :(
You dont get any chatter with the spec?
Joseph Dell
Atlanta, GA 30338
no chatter w/ this spec! installed on the advice of Mr 1TONY1 and it was good advice. A heck of a lot better than the RPS POS!
for 2k, is there a lifetime warrantee with the McLeod? and does it come w/ a free toaster???
JD
