What is the Torque required for Gen2 heads
Viper TT/10
you know if you buy an owners manual for $100 must of the questions you post would be answered.
vegasviper
Guest
Its on order, however id like to install heads tonight
vegasviper
Guest
Hey Viper TT
I see that you gave up trying to work on your car and got a tuner to do the work for you. Some times you just have to know your limits
Dont blow anything up
hemibeep
Tampa FL
I am almost sure it is 45lbs first round, then to 90lbs on the second round,
can't remember the sequence though.
vegasviper
Guest
Thanks, they are stock head bolts.
Should i install bolts dry?
Cape Coral, FL
Joe- If I recall correctly, arent the ARP studs w/moly 86 lb/ft? I am almost positive thats what they are spec'd at from ARP...I dont even think they give an "engine oil" spec, only moly.
Joseph Dell
Atlanta, GA 30338
You are correct. less tq w/ moly. that's why i don't use it... i can never remember the specs of the moly.
For a car like vegasvipers, head studs would be a huge benefit... 10lb of boost w/ stock head bolts isn't a lot of clamping force...
but, just my .02...
JD
revived_gearhead
Charlotte, NC
This info is straight from Arrow racing. If using the stock head bolts, and they can be reused if threads are not nicked or burred, install dry because the bolts have a special coating, and as J.Dell said, torque in three stages.
45-85-110 ft lbs. This is on a GenII. Hope this helps!
Dwight
Viper TT/10
Hey Viper TT
ya when you push the envelope you do break stuff. oh mr do all your work yourself tell brad hi for me next time you go in for(lousy)viper service.
i already got my satisfaction rebuilding the motor, installing my own blower, and tuning it all myself. i wanted an expert tuner to install my tt set-up this time around.
vegasviper
Guest
I only use Brad for installs that i cant do at home, belive me Brad is not a knowledgeable Viper tech and half asp most thing he does on a Viper.
HavikPerformance
