Who's ran 11's dead stock ( or close)
Twister
Gen 3 stock times;
11.7 @ 123 mph ; Convertable=> Motor trend 2004
11.77 @ 123.63 mph ; Convertable=> Motor trend 2003
12.1 @121 mph ; Convertable=> Car and Driver 2003
12.1 @ 120.9 mph ; Coupe=> Motor trend 2007
12.19 @121.2 mph ; Coupe=>Popular Mechanics 2007
12.1 @ 120 mph; Coupe=> Automobile 2006
12.1 @ 119.3 mph ; Convertable=> Road and Track 2005
GEN 2 stock times:
11.77 @ 120 mph ; Viper RT/10 => High Performance Mopar Magazine Fall/2000
11.97 @ 118.88 mph ; Viper GTS => Popular Mechanics Magazine August/1997
11.98 @ 117.7 mph ; Viper GTS => GM High-Tech Performance Magazine January/2002
12.08 @ 118.51 mph ; Viper RT/10 => Popular Mechanics Magazine July/1999
12.1 @ 121 mph ; Viper ACR => MotorWeek /2000
12.1 @ 120.5 mph ; Viper GT2 => Motor Trend Magazine April/1999
12.12 @ 118.43 mph ; Viper GTS => Popular Mechanics Magazine 1997
12.19 @ 119.15 mph ; Viper ACR => Motor Trend Magazine November/2000
12.2 @ 119.8 mph ; Viper GTS => Motor Trend Magazine July/1999
12.2 @ 118 mph ; Viper GTS => Car & Driver Magazine July/1997
12.2 @ 118 mph ; Viper RT/10 => Car & Driver Magazine October/1997
12.3 @ 118.19 mph ; Viper RT/10 => Motor Trend Magazine August/2000
IM STILL WORKING ON THE GEN3 LIST AND WILL ADD THE GEN 4 LIST WHEN IT'S COMPLETED
__________________
Looks like the SRT10's are usually hovering around 121 mph trapps..Thats good for 11's no prob..
So who'***** the mark dead stock or gotten close..Post em up cas the gen2 guys are makin us look bad LOL....
I have no drag strip on my island, so sadly no real numbers to put down for my self
oufan2929
I've gone 11.8@120 very easily, but I've got a clutch that's on it's last leg, so I wasn't able to slip it as much as I'd like. There's no doubt in my mind that I could at least get an 11.6 on the stock wheels, and maybe an 11.5 or better on some DR's...
Hamrhead
eastern, Pa
Earlier this Spring my '06 Coupe went 11.90 @ 122.34 completely stock. 1.96 60', 70 degrees, and somewhat humid.
Better weather and some more practice I figure I could've improved on that.:)
sparty116
Michigan
Just for some clarification, but Motor Trend uses corrected times when they report their numbers, which means the cars never actually turn the times they report.
They are the only magazine out of the big three that do it that way.
DMan
Maryland
Check my sig, 1 week old, bone stock with a cardboard license plate.
Haven't run with my new mild bolt-ons, maybe I'll get out for a run before it gets too cold.
Dan Cragin
LA, CA
We ran 11.6 at 119mph on a stock 97GTS with MT's and Purner wheels.
slaughterj
What does that mean?
sparty116
Michigan
They run the car through the 1/4 mile like normal. They then take the time run and plug it into a rather large equation that re-computes the 1/4 time/speed based on standard conditions (not sure on specifics). Depending on conditions, it could go up or down. 99.9% of the time the corrected times are faster than what the cars actually ran, sometimes by a substantial margin.
There is ongoing debate on the accuracy of the correction equations used, as some say there are just too many variables, and you cannot accurately correct the times. Another major flaw with the system is it does not take into account a cars induction system (N/A, SC, TT), which all react differently to changes in atmospheric conditions.
For example, you will notice that MT does a lot of their testing at Ford's Arizona proving grounds, which is situated a few thousand feet above sea level and is in the middle of a hot desert. There is no way a car tested at that venue will lay down the same times it would if it were at a cool, near sea level location. They correct the number to account for this.
It is a way for them to keep their performance numbers similar, because they test at multiple locations under different atmospheric conditions. It's a B.S. way of reporting performance numbers, but hey, it sells magazines.
Viperless
MN
I ran 12.07 @ 117 in my bone stock '97. I'm pretty sure I have it on video somewhere.
T
Twister
man quite a few 11 second bone stock passes..keep them coming ( and the low 12's as well)
..I cant wait to make a list..
viperjim
Maryland
11.85 @ 121 stock with runflats and 11.68 with a few bolt-ons. I'm looking for 11.4's:D
T
Twister
is it just me or are the 2003's a lil faster?????
Canyon707
Napa California
:drive:
11.9X@121 bone stock o3 with run-craps then ran 11.9X right after but @ 120.Xmph
run craps are just that the sidewalls are to hard the tire is to heavy and It is difficult to keep the car hooked up. Best bet... Drag radials, Quaife rearend, the stock rearend is basically junk with its hyd setup, good shocks and springs, its all about keeping your wheels on the ground. Thats what gives you good times. Not sliding and hopping down the track.
SimpleJack
