You may want to check the Eibach site as longer springs (even at the same spring rate) tend to allow more travel. This can be OK if you want your car to sit at or above stock height, most of us don't. If you lower your Viper much with longer than 8-inch springs, you will have "rubbing" issues, especially at the rear of the car.
8-inch springs are a pretty good compromise for ride, spring travel and overall handling. I have run 500 / 800 and 600 / 800, 8-inch springs on two of my "street" Vipers. Again, you just can't go too low without rubbing.
7-inch springs tend to be more aggressive. I've run 700 / 900 and 800 / 1100, 7-inch springs on Vipers and they work well too. You can lower the car a bit more with these springs as Mark says.
I run 6-inch springs on my 09 ACR as I wish to minimize travel (body roll) and maximize handling. Started with 900 / 1300 and am now at 1100 / 1500 (comp coupe stiffness). These work extremely well on the track with Moton Race Shocks (and the down force the wing and splitter make).
Dan
