Why so much heat?
Blue Pilot
N.E. Ohio, US
Can anybody answer as to why the Viper produces so much more heat than my other vehicles. When I pull the viper into the garage after driving it, my garage gets to be a sauna. My truck and durango do not do this nearly as bad as the viper does, yet they run at about the same temperature.
Just curious, thats all.
Thanks.
Chuck 98 RT/10
tampa, fl USA
Does your truck and Durango have a 488 cid V-10??? Legit question, I'm not trying to be a smartass. It just seems logical to me that two more cylinders and a lot more cid would produce more heat.
B
Blue Pilot
N.E. Ohio, US
Good point, but the viper has an aluminum block, where as the 360's in my trucks have cast iron blocks, which hold heat longer. :p
Magicboy2
Philadelphia, PA
Well, by that logic, because the aluminum block DOESN'T hold the heat longer, that means it dissipates it faster, thus making the heat buildup in your garage more noticeable.
Chuck 98 RT/10
tampa, fl USA
Put 10 1,000 degree torches on a piece of aluminum and 8 1,000 degree torches on a piece of iron half the size of the aluminum, then get a...forget it. Call the math majors.
BruceW
San Diego
I believe aluminum has a higher specific heat value than iron (takes more thermal energy to produce a temp. change) so once it's hot it releases more energy when cooling back to room temp. Also, there's a lot of thermal mass in the Viper, what with the big block, all of the fluids, and the tranny (and possibly the rear end).
B
Blue Pilot
N.E. Ohio, US
Thanks, that all makes sense. If I did not live in Florida and needed a secondary house heater the viper would work just fine. It stays hot for a very long time, much longer than my other vehicles. I am just learning about this car, as I have only had it for 2 weeks.
snakebitdave
Mi, USA
If they all your vehicles run at the same temperature 200 degrees is 200 degrees is 200degress. I would agree with others in that there is more mass. Larger engine, headers, exhaust system, radiator, etc. Also the heat has more openings to exit quicker than a "normal" vehicle. It is a plus in Michigan's heating season in that it helps to warm up the garage.
BruceW
San Diego
I do use the V to warm the house in winter (for the few weeks it needs it). I have a fan mounted in the wall between the garage and the house. Vipers do make good secondary heaters.
Got Venom
SUNNYVALE,CALIF.
In mild Sunnyvale, California, it does get warm in the summers, and it is a pain to have the garage get 20+ degrees warmer after you pull the Viper in, so this season, I'm going to get one or two of those solar powered attic/roof fans to draw the heat out of the garage.
MoparMan
Las Vegas, NV
In addition to all the other answers above, consider that a byproduct of making horsepower is making heat. The engine in your Durango is at best a 360 (assuming its an R/T) and it's making about 250HP at the flywheel. Your Viper is a 488 and is making at least 410 at the rear wheels (probably about 15% more at the flywheel).
SimpleJack
