EXECMALIBU
HAS ANYONE CLOCKED THEIR SRT FOR THE 0-60 TIMES?.. THE GEN II CARS ARE SUPPOSED TO BE 4.1 SEC..
WOULD 3.73 GEARS MAKE A GEN II FASTER 0-60??
For Real? I thought Gen 2s could get to 60mph in 1st gear.The main resaon is that the SRT is geared to exceed 60mph in 1st gear whereas the old car would hit 57mph and with 373's you will still have to shift and getting traction will be much harder.
The Viper required a longish throttle lift between shifts. Fortunately for the Dodge, the 1-2 upshift occurs after 60 mph, and third's good until well past the finish(1/4 mile). In fact, its not difficult to drive a Viper using only third gear. It's got more than enough torque to start in third, 70 mph in that same gear is just 3900 rpm, and the redline doesn't come until past 120 mph!
From Motor Trend:
Motor Trend, August 2000 issue;However I think I recall reading that quote and it being about the SRT, it was recent wasn't it?
The SRT-10 Vipers share the same 3.07 gears and 6000RPM redline as the GenII Vipers do. So most likely they also hit redline at 57MPH. But 57MPH is VERY close to 60MPH, so maybe you actually hit the rev limiter at a couple hundred revs higher, seeing
60MPH in 1st.
The engine's redline has risen 100 rpm, to 6100 rpm, with maximum power achieved 500 rpm below that.
. But I'm still waiting to see a full magazine test done with a broken-in production SRT-10 Viper.
I am hoping to see a faster than 3.9 second 0-60 run, and sub 12 second 1/4 mile times, if they can get a skilled driver behind the wheel.
Testing mules had supposedly ran as fast as 212MPH.
GTSs have a cd of 0.35. Anyone knows the SRTs cd(top up)?
I'll be very happy if I see some mag getting 200mph out of the SRT. 212mph, I will fall from my chair . The more aerodynamic(I think, not sure), more powerfull(580hp) Lambos top speed is around 208mph-210mph(or so I've read). What was the HP figures of these mules? Whats the real HP number for the SRT 520hp-540hphp?
Ok come on this is the SRT forum. Does any one with an SRT actually post in this section or just us wanna bes.
Some rich [******] with an SRT can you just tell us if you can go up to 60 MPH in first gear.
From the "heartland oflanded gentry" I will say this;
My SRT now has 1,534 miles on the ODO (yep, I had my butler check it to make sure)) and I have calibrated my G-Tech "Competition Pro" to my best abilities and research... actually, my butler did that for me because it was my spa time! Now that I have qualified my bad self, I will tell you my findings.
My SRT is making repeated 0-60 runs (on scoped out, public highways, as I OWN the local Militia) of 4.0 seconds. It is just stock, and I am a rookie just having fun.
Yes, the SRT does get to around 60mph when you gotta shift to 2nd. I am not interested in blowing it up; but the tires are spinning, trees are passing at warp speed, and each run is a learning experience. My butler just quit because he can't record and crunch the numbers fast enough. I got pissed at him because of his mathematical incompetance... crap, I even missed my pedicure because he couldn't balance my checkbook at the same time!
Heck, if I can run "unofficial" 4 sec 0-60 while taking my butler along (together, we are 600 pounds or so) then surely someone will crack a 3.7 or 3.8 on the "slim-fast" plan and on a flat track.
Seriously,
Jim
