0-60 HOW MUCH FASTER IS THE SRT THEN A GEN II? (BOTH CARS STOCK)
EXECMALIBU
MALIBU CA
HAS ANYONE CLOCKED THEIR SRT FOR THE 0-60 TIMES?.. THE GEN II CARS ARE SUPPOSED TO BE 4.1 SEC..
WOULD 3.73 GEARS MAKE A GEN II FASTER 0-60??
M. ROD
Borikén
Best I've seen:
GTS=> 3.89sec.
SRT-10=> 3.9sec.(Pre-production prototype)
Craig 201 MPH
Toronto Ontario, Canada
The main resaon is that the SRT is geared to exceed 60mph in 1st gear whereas the old car would hit 57mph and with 373's you will still have to shift and getting traction will be much harder.
Of course if you have a superviper with 6,000 h.p. because the current car is crap it will beat the SRT.
M. ROD
Borikén
For Real? I thought Gen 2s could get to 60mph in 1st gear.
From Motor Trend:
The Viper required a longish throttle lift between shifts. Fortunately for the Dodge, the 1-2 upshift occurs after 60 mph, and third's good until well past the finish(1/4 mile). In fact, its not difficult to drive a Viper using only third gear. It's got more than enough torque to start in third, 70 mph in that same gear is just 3900 rpm, and the redline doesn't come until past 120 mph!
Craig 201 MPH
From Motor Trend:
Strange. I read in motortrend as well awhile ago that they hit 57mph, I think I also read it in chrysler published material.
However I think I recall reading that quote and it being about the SRT, it was recent wasn't it?
M. ROD
Borikén
Motor Trend, August 2000 issue;
Cover Story:
Shootout: Corvette ZO6 vs Mustang Cobra R vs Viper RT/10.
J DAWG
MS
For what its worth, I have to shift into 2nd before 60 in my Gen II, around the 57 mph mark.
I also assume, with everything being equal, stock for stock an SRT would be a touch quicker to 60. I think DC made sure the next generation Viper was faster than the last(stock). Just makes sense. :usa:
Snakester
Morgan Hill
The SRT-10 Vipers share the same 3.07 gears and 6000RPM redline as the GenII Vipers do. So most likely they also hit redline at 57MPH. But 57MPH is VERY close to 60MPH, so maybe you actually hit the rev limiter at a couple hundred revs higher, seeing 60MPH in 1st.
I haven't hit the limiter myself, and except for the few rare folks who have broken in their motor and ran their SRT-10 hard, I'd guess that most SRT-10 Viper owners haven't either.
Regardless, the SRT-10 Viper does have more HP and torque, so potentially they are quicker than all previous stock Vipers. But I'm still waiting to see a full magazine test done with a broken-in production SRT-10 Viper.
I am hoping to see a faster than 3.9 second 0-60 run, and sub 12 second 1/4 mile times, if they can get a skilled driver behind the wheel.
-Dean.
CHAD
Sarasota, FL
Don't forget the SRT has a taller rear tire (1.3"), pushing it faster with the same gearing in the tranny and rear at the same rpm. We know the Gen II will run 57mph so the SRT will run exactly 60mph at the same rpm and gearing with the taller tire.
Chad
M. ROD
Borikén
60MPH in 1st.
Motor Trend's editors got 60+ mph in 1st gear, that was achieved in a Viper RT/10. When a car's performance is being tested they avoid to hit the rev limiter, and they make more than one run.
I thought that the SRTs redline was 6100 rpm;
From Car&Driver:
The engine's redline has risen 100 rpm, to 6100 rpm, with maximum power achieved 500 rpm below that.
But who knows, after all they are the same magazines that are use to drive Echos and Civics. I rather believe you guys that DO own the cars. :)
AMEN TO THAT BROTHA!. :usa:
Take care, Mike.
BACKNBLACK
NY
Isn't it fact that having a convertable you would have more drag on it slowing the 1/4 mile times, even when top is up??
Snakester
Morgan Hill
The SRT-10 Viper is supposed to have a much lower drag coefficient than the R/T10, and comparable to the GTS (obviously with the top up). Testing mules had supposedly ran as fast as 212MPH, which would have required MUCH more power if it had close to the drag of the R/T10. And yet the R/T10 has the fastest magazine 1/4 mile time for any Viper (at 11.77/118MPH) despite having comparable power to the GTS and far less than the SRT-10, and having much worse aerodynamics.
-Dean.
M. ROD
Borikén
GTSs have a cd of 0.35. Anyone knows the SRTs cd(top up)?
Testing mules had supposedly ran as fast as 212MPH.
:eek: :eek: :eek: :cool:
I'll be very happy if I see some mag getting 200mph out of the SRT. 212mph, I will fall from my chair :D . The more aerodynamic(I think, not sure), more powerfull(580hp) Lambos top speed is around 208mph-210mph(or so I've read). What was the HP figures of these mules? Whats the real HP number for the SRT 520hp-540hphp?
Paolo Castellano
Elburn, Il, USA
I think the Gearing is such that it could go 212 MPH @ 5900 RPM, but I do not think the stock SRT has near enough power to go 212 MPH here is a chart:
As you can see, here is a chart that shows how much RWHP you need to go a certain MPH given a certain rear end gear, trans ratio, drag coefficient and frontal area. I think I remember a posted CD for the SRT of .32, I know the Corvette has a frontal area of 21.3 sq ft. I have been generous here giving the SRT a .31 drag coefficient and a frontal area of only 21 sq ft. Here you see that with these #'s 447 RWHP is needed to go 201 MPH and 518 RWHP would be needed to go 212 MPH!
ENTER AXLE RATIO 3.07
ENTER GEAR RATIO 0.74
ENTER EFFECTIVE TIRE DIA 27.4
RESULTING CONSTANT 27.87
ENTER Cd 0.31
ENTER FRONTAL AREA (FT^2) 21
RESULTING CONSTANT 1.407E-05
ENTER HP
RPM HP REQ'D SPEED AVAILABLE @ RPM
3500 122 126 400
3600 132 129 430
3700 142 133 472
3800 153 136 495
3900 164 140 508
4000 176 144 522
4100 188 147 548
4200 201 151 570
4300 214 154 585
4400 228 158 595
4500 243 161 607
4600 258 165 628
4700 274 169 647
4800 291 172 675
4900 308 176 695
5000 326 179 700
5100 344 183 718
5200 363 187 740
5300 383 190 770
5400 404 194 790
5500 425 197 815
5600 447 201 825
5700 470 205 835
5800 493 208 844
5900 518 212 835
6000 543 215 827
6100 568 219 820
6200 595 222 817
6300 623 226
6400 651 230
6500 680 233
You probably ask yourself how I know this formula works, right? here is one for a gen 2 GTS:
It shows 412 RWHP to go 186 MPH(Which is right on the money for the top speed of a stock Gen-2 GTS=> This could also be a little conservative considering a Bone stock 1997 GTS went 192.6 MPH in the magazine)
ENTER EFFECTIVE TIRE DIA 26.3
RESULTING CONSTANT 29.03
ENTER Cd 0.35
ENTER FRONTAL AREA (FT^2) 22
RESULTING CONSTANT 1.664E-05
ENTER HP
3500 123 121 400
3600 133 124 430
3700 144 127 472
3800 155 131 495
3900 166 134 508
4000 178 138 522
4100 191 141 548
4200 204 145 570
4300 218 148 585
4400 232 152 595
4500 247 155 607
4600 263 158 628
4700 279 162 647
4800 296 165 675
4900 314 169 695
5000 332 172 700
5100 351 176 718
5200 371 179 740
5300 391 183 770
5400 412 186 790
5500 434 189 815
5600 457 193 825
5700 480 196 835
5800 504 200 844
5900 529 203 835
6000 555 207 827
6100 582 210 820
6200 609 214 817
6300 638 217
6400 667 220
6500 697 224
Not a bad little spreadsheet, huh?
Snakester
Morgan Hill
When I read about the 212MPH runs in testing I assumed that the particular test car had much more than the 500HP rating, but the key here is that as drag goes up, it takes MUCH more power to attain high speeds (as seen by the numbers above).
And it would have taken a huge amount of HP to pull 212MPH in say an R/T10 with a 0.50 cd.
I expect that the SRT-10's top speed will be somewhere between 190 and 200MPH, which is awesome for any car, and moreso for a convertible. :laugh:
But at lower 1/4 mile speeds, drag is not as much of a factor (as long as you have the top up.) ;)
And having 3.73s is not always an advantage in getting faster 1/4 mile times because you have a much greater chance of wheelspin, possibly making the car actually slower than stock gearing unless you have slicks, or hook up perfectly.
-Dean.
Craig 201 MPH
I can easily see it attaining 200+
6th gear is supposed to be much more usable now plus it has better aerodynamics.
The fastest ragazine top speed for a GTS was 192MPH I think the new car can easily pull 8 mph given the same room to do it in.
MichaelP
Orlando FL and Seneca Lake NY
Ok come on this is the SRT forum. Does any one with an SRT actually post in this section or just us wanna bes.
Some rich [******] with an SRT can you just tell us if you can go up to 60 MPH in first gear. :)
GR8_ASP
Well I can speak for the northern SRT owners. Just not enough good warm weather to get past the 500 mile break-in period. 272 miles to date on mine and no driving this week due to freezing temperatures.
I recall the drag coefficient being stated elsewhere and it was not as good as the GTS. Frontal area was slightly different as well. Doubtful you will see above 190 stock.
Regarding 6th gear. It may be more usable but will not be the top speed gear.
Y2K5SRT
Overland Park, KS
Speaking on behalf of the poor ************* ***** SRT owners, I can tell you on good authority that it cuts out at approximately 59.7 mph in first gear. And no, I won't do it again. ;)
Chris
jwwiii
Waukee, Iowa USA
From the "heartland oflanded gentry" I will say this;
My SRT now has 1,534 miles on the ODO (yep, I had my butler check it to make sure)) and I have calibrated my G-Tech "Competition Pro" to my best abilities and research... actually, my butler did that for me because it was my spa time! Now that I have qualified my bad self, I will tell you my findings.
My SRT is making repeated 0-60 runs (on scoped out, public highways, as I OWN the local Militia) of 4.0 seconds. It is just stock, and I am a rookie just having fun.
Yes, the SRT does get to around 60mph when you gotta shift to 2nd. I am not interested in blowing it up; but the tires are spinning, trees are passing at warp speed, and each run is a learning experience. My butler just quit because he can't record and crunch the numbers fast enough. I got pissed at him because of his mathematical incompetance... crap, I even missed my pedicure because he couldn't balance my checkbook at the same time!
Heck, if I can run "unofficial" 4 sec 0-60 while taking my butler along (together, we are 600 pounds or so) then surely someone will crack a 3.7 or 3.8 on the "slim-fast" plan and on a flat track.
Seriously,
Jim
Daffy Duck Viper
Austin, TX. USA.
Seriously,
Jim
TRANSLATION:
Get in line challengers, 'cause you're about to have your @ss handed to you real soon. LOL
tonychicken
