05 SRT WIRES
adesrt
I have replaced the spark plugs, and am about to replace the wires. I am reasonably good with mechanics what is the correct procedure for removing the intake manifold? my main concern being fuel under pressure.
Any advice appreciated
Ade
TowDawg
Chattanooga, TN
Qualitywires.com Adam is great to deal with and makes great wires. I bet a large majority of people who have replaced their wires go with Adam. Nothing else will be on my car.
A
adesrt
Thanks for the info, but what i need to know is how do i release the fuel pressure before disassembly. Or am I wrong?
Thanks Again
call me...
Forget the call...remove the fuel pump relay from the PDC, start, run engine til out of fuel. Attempt restarting until it will no longer run...turn key OFF...reinstall relay.
You may set DTC's...will need DRB III to clear.
Read Nader's great write-up!!!
You need a service manual!!!
Unless your wires are bad this is a lot of pain for little gain in my opinion.
That said, have fun changing your wires!!! :)
