1994 Clutch pedal movement. Need advice and help!
Qualitywires.com
Louisville, KY
On my 1994 Viper, I noticed on my clutch that the pedal is a bit loose. It has side to side movement and doesn't seem tight on the forward and backward movement too..but most of al I can jiggle the pedal side to side. In my manual..it doesn't show anything about tighting the pedal. Any advice would be helpful!
Thanks!
Jim Sullivan
Sanibel Island, FL,USA
Seems to be a common problem. Something to do with a bad bushing in the pedal assembly. Go to the "search" section on the main page and look under "clutch" and you will find a couple of remedies.
Vip-RT10
Clearwater,FL.USA
Adam...i sent you an e-mail showing the set up. I would try to tighten the bolt first, then see what to do and if something is bent or fell out. Keep us informed.
potterb4
