2002 Viper "Heater"
DviperX
Louisiana
2002 Viper \"Heater\"
My car has 2000 miles on it and the heater does not blow hot air. Of course I am going to bring it back to the dealer which he thinks it could be the thermostat. Has anyone out there experianced any problems like this?
Magicboy2
Philadelphia, PA
Re: 2002 Viper
Set the dial to floor vents and turn on the heat after your car's been running for a little while. Reach your hand down there. If you feel hot air coming out, then your heater is fine.
Heat only comes out of the floor and defroster. The main front vents will not blow heat. It's stupid but just how it's designed.
FE 065
MI
Re: 2002 Viper
I had the same problem on my 2002. The cable end had slipped off the acutator rod.
It's under the hood towards the windshield a bit from the plastic HVAC plenum on the passenger side.
It has a loop on the end of it-check and make sure it's ontop of the post it's supposed to be on.
D
DviperX
Louisiana
Re: 2002 Viper
Thanks guys! I believe the Enthusiast has it. I drove the car for 45 minuets with the floor vents on only so that is not it.
FE 065
MI
Re: 2002 Viper
I'll have to get that 'Enthusiast' thing changed, I'm on my third Viper, and a VCA member..
D
DviperX
Louisiana
Re: 2002 Viper
Yes! Thats what it was. The cable loop slipped off the actuator. Thanks a lot!!!
zeeshan_k24
