pauljkopick
How much road do you think you would need to have to slow down comfortable say to 70-80MPH after attaining the above MPH.
Well I get to 190mph from 70mph in 7/10ths of a mile and slow down to 70-80mph in about half that distance or less.
i will always cherish the initial misconceptions i had about you..we're all refreshed and challanged by your unique point of view on this thread .The amount of road needed to slow down from 201 to 70 MPH, or the amount of road needed to get to 201 and then back down to 70 MPH?
It really depend on your Power and brakes!![]()
i will always cherish the initial misconceptions i had about you..we're all refreshed and challanged by your unique point of view on this thread .![]()
i really dont know what your problem is butt i'll bet its hard to pronounceThe amount of road needed to slow down from 201 to 70 MPH, or the amount of road needed to get to 201 and then back down to 70 MPH?
Another FABULOUS and contributory post by roofum. Keep 'em comin' retard... Everyone LOVES your off-topic, smart-@$$ attitude. Here's something to treat your mental diarrhea:
once again you have an answer for every thing and the solution to nothing. your answer is wrong sparkyTo respond to the initial post: To bleed off 131 MPH of speed, assuming a constant deceleration rate, and let's say you give yourself 30 seconds to do it, you'd need 5764 feet, or 1.091 miles to slow down from 201 to 70. If you double your deceleration rate and do it in just 15 seconds, you'd need 2882 feet, or .545 miles.
Assuming of course I did the math right.![]()
NoRice your speed & slowing that good,I mean that damn good. Check my signature still a Viper hanging around.
Cody Flordia if, just talk at this point.
Anyone who has done this would like to hear your comments.![]()
Well you obvioulsy have some extra power. In my Gen3, I have gone from 70-198mph in 7/10ths of a mile and slowed down to less than 70mph to get off the freeway in less than 1/2 mile at the next exit the last 2 Sundays about 5 times. So if you have decent brakes on your car like the Gen 3 then slowing down isn't an issue. I can say I needed every bit of the 3/8 - 1/2 mile to slow down safely. In fact this past Sunday after hitting 198mph I started to brake and blew my vacuum hose off so I lost all my power brakes. Try slowing from 198mph to 70 or less with no brakes practically! Scary stuff. I almost didn't make it in time as I had to change lanes and get into the shoulder to get slowed in time.Honestly how stable are our cars at that speed? Not that my Viper could currently make it that fast, but if it could....Window problems?
And doing 198mph on a freeway has always been safe place to test this theory. I like going fast just like the next person but 198mph on a public road is pure insanity.
That's the Best answer to the original question I've seen. Looks good to me. But I don't do Math only turn wrenches. LOL
Thanks. Like I said, it's a guesstimate which assumes several constants that really would be variables (brake force, friction, etc.), but I think it's close enough to make an educated guess. Here's the math if anyone cares to scrutinize:
Assuming a constant rate of deceleration (i.e. constant brake pressure), the mean speed during the decel is 135.5 MPH ( (201-70)/2 + 70 ). That means that half of the decel period will be spent between 201 and 135.5 and half will be spent between 135.5 and 70.
135.5 MPH mean speed * 5280 ft/mile = 715440 Feet per hour.
715440 FPH / 3600 seconds/hour = 198.73 Feet per second.
198.73 FPS * number of seconds in decel (I used 30 initially) = 5961.9 feet
5961.9 ft / 5280 ft/mile = 1.129 Miles in 30 seconds.
30 seconds is a long time to be braking, the Viper could certainly do it faster. It's easy to play with the numbers from there....just multiply 198.73FPS times the number of seconds you think you can make the transition from 201MPH to 70MPH in, and you'll get a guesstimate of distance in feet.
If you can do it in 10 seconds, then it would only take you 1987 feet, or .376 miles. That's inline with what NoRice said he was able to do it in when he was really honkin' on the brakes. NoRice, how long would you say it took you, timewise to do that braking? Does the math jive with your experience?
I think I used 131 MPH as the mean speed in my earlier post which is why the numbers are a tad different, but still close. And I'm no math guy, but I've slept at a Holiday Inn in the last year.![]()
