John N
There is a center pin through the plastic, kind of like the center shaft of a standard rivet. Pull out that center pin with a pair of pliers and the outer part will become free (the pin just expands some plastic dogs on the inside of the clip, which holds against the inside of the panel). Install in reverse order, i.e. install the outer part then run pin back through the middle.
