Go Fast For Life
- Joined
- Nov 25, 2003
- Posts
- 374
- Reaction score
- 0
Can I reset the PCM on a 97 GTS by pulling fuse #15 from the engine compartment fuse box?
Viper 2000:
it is not a shock to the system, every electrical system (your house is not much different) has capacitance relative to the reference or ground plane. This is where the energy is stored and all you are doing is bleeding off the stored charge. You can let time bleed the charge or you can take the positive cable and touch the frame. Either way is effective.
I just feel the PCM connectors are too fragile and the harness far too taunt. I do not like fooling with them if at all possible.
