Access to Back Up/ Reverse Light Bulb
Fast Eddie
How do you gain access to the reverse/ back up light bulb in order to change it? The bulbs in the brake light/ turn signal encasement are easily accessable. The reverse bulb is visible, below the brake light assembly, but out of reach.
Thanks,
Ed
F
Fast Eddie
After removing the cover to the inner fender, you need to remove three 7/16" nylon bolts (2 from inner fender and one from trunk), disconnect the 3 bulbs in the brake light/ turn signal unit it and remove that encased unit by pulling it out of the back of the car. Once that encased unit is removed, you have access to the reverse light bulb.
Cheers,
Ed
BarryLB
