Advice - Stripped Sway Bar Mount Nut
TexasPettey
Austin, Texas
While doing some work on the car, I removed the sway bar and reinstalled. One of the nuts stripped. Since the nuts are welded to the inside of the frame rail, it's a bit of a pain. :mad:
I couldn't find any access points to the nuts on the frame. It looks like they were welded in and then the frame was closed. Are there any options for accessing those nuts inside the frame rail, or am I stuck with doing a rethread?
dave6666
Funny you should mention this. One of my rear exhaust mount screws has stripped in the frame - welded nut in the frame such as you describe.
I can actually access the back side of it by pulling the fender well liner back, as it's the one near the rear wheel well, but I'm going to do the professional repair and put a in weld nut.
Drill out the stripped nut in the chassis, then weld in one of these from McMaster Carr. Professional fix.
Jack B
NE Ohio
A little easier might be the rivet inserts that contain a machine thread. It would still have to be drilled out.
T
TexasPettey
Austin, Texas
Thanks. That looks like the right fix. I do have enough access. I'm going to pull the front fascia off to see if there is access to the back side of the nut from the front of the frame.
got one
Castle Rock
Let me know when you are going to pull it off...would be cool to come see it!
T
TexasPettey
Austin, Texas
It will probably come off this weekend. I got pulled away from TX for work, so I haven't been able to pull it yet.
got one
Castle Rock
Damn Ryan, you'd think those were Madonna's ******* fixing to come off. :D
:lmao::lmao::lmao::lmao::lmao::lmao:
might as well be Dave. I need to pull my fascia off and have been scared to death to do so. I hear plenty of horror stories about it. So in this case I would take pulling my fascia off vs. pulling off Madonna's underoos...:nono:
dave6666
I've had mine off enough times that I'm good at it. It the Gen 1 harder to do?
