Air / Fuel gauge
Nixon's SRT
Autometer is straight forward. Install sensor in exhaust, run harness and add power and ground and mount the gauge. I put mine on the steering wheel.
GTS-R 001
California (north)
If you want to use it for tuning versus trying to watch it while you are accelerating then you need to be able to datalog with RPM,
rw99
Castro Valley, CA
I use a Dynojet Wideband 2 in my Challenger, with their configurable LCD display/logger. I love being able to read digital A/F gauge heads-up at WOT, mid-pass...
Rich
rw99
Castro Valley, CA
did you connect to the downstream 02 sensor? or did you tap in?
The supplied Bosch wideband O2 sensor feeds a small central module, from which both the AFR gauge and the LCD display/logger draw their data. A weld-on **** for adding the wideband sensor is included in the package.
speedracervr4
Lancaster, PA
AEM recently came out with their "Fail safe" wide band that allows logging of multiple items such as boost,AFR,RPM all at once. It also lets you set up a trigger so if a parameter goes out of limit your able to retard timing, cut boost, etc.. I currently run the regular AEM wide band in three of my vehicles and havent had any issue with them.
