air to air or keep my paxton water to air
Fort Lauderdale, Florida.
should i use a front mount intercooler or stick with my water to air
I would suggest to stick with the air to liquid unit. The air/air is more restrictive for your application. You would need to increase the boost in order to compensate for the restrictive loss from the air/air unit. Consequently, you will incur belt slip and more load on the crank and damper to overcome the belt slip.
Also the thicker air/air core complicates engine heating (or rather engine cooling) by blocking the incoming fresh air.
Try to stay with what works best for your application.
I hope this was informative for you.
Regards,
Doug
vipzilla
CAPE COD MASS.
thanks doug and i knew plum crazy would have some input for me i was gonna email you personly when i first thought of doing this thanks guys !!!
vipzilla
CAPE COD MASS.
does any one know if there is a better water to air intercooler then the one that came with my paxton????
tbone96
