Airbag Recall Replacement Incorrect Tales
fhrzr1
Cocoa, Florida
No disrespect to anyone. On my 2005 Gen 3 Viper, I just removed the airbag module and replaced it with the new one.
I will post pictures and procedure in the near future.
Here are some of the facts.
1. Steering wheel does not have to be removed, loosen or messed with at all. It is nowhere near the module.
2. Module is located under the radio.
The module under the radio
I was reading the service bulletin on that as I was thinking about replacing it myself on my 2004 and didn't think you needed to take off near what it was telling you to. I think it certainly helps and makes things easier, but I also think if you are clever or have smaller hands it's not that bad.
I think the main reason they tell you to take the steering column out is to make it easier to remove the whole plastic dash trim. If you just loosen the nuts on the column support and let it fall down though you can wiggle the dash trim panel out though. I've done it what feels like a half dozen times now between the various things I've done on my car.
hlieber50
Hi, Had my 2005 airbag module replaced by a dealer last Wednesday. Leading up to my appointment I had an argument with the service tech who would be doing the replacement. He insisted that the module was located under the console like 99.99% of all Chrysler products. I also needed my Cluster Bezel replaced because it was cracked. He said it would be done at additional charge. I said fine but when the car was done it was a no charge since the module was in the dash under the radio. I guess he felt guilty about our argument.
F
fhrzr1
Cocoa, Florida
To remove the dash trim, no need to loosen steering wheel.
1. Remove plastic cover for turn signal and light switch, 2 screws( 1 minute).
2. Remove turn signal/light switch unit, 2 screws and 2 electrical plugs ( 1 minute).
3. Take dash bezel out.
Raheel
San Diego
I already have my dash open for some other stuff that I am doing on the car and the module is sitting right in front of me and it would take me less than 60 seconds to replace it.
The question is how do you get the new (replacement) module since it is a recall? Can I just call FCA and ask them to ship me a replacement and I ship them the original back? How does that work?
Raheel
San Diego
Never mind. Just read your other post on the topic under a separate thread.....
I know what to do now.
Thanks for all the info!!
