Aluminum Flywheels..
Sean Roe
Jacksonville, FL
As many of you know, aluminum flywheels offer two distinct advantages when used to replace steel flywheels. Advantage #1; the engine is able to accelerate faster because of the reduced rotating mass and mass centerline. Advantage #2; the engine rotating assembly (crank, rods, bearings, etc.) all last a little bit longer because they are under less load.
If you have ever been interested in an aluminum flywheel, but felt that perhaps the cost of the parts at $625 to $950 didn't make it worthwhile for the performance gains, here's a chance to purchase one at the right price. Go to the new products forum and read the aluminum flywheel post I put up a little while ago. It may be just what you're looking for.
Sean
