I am of the midset that it needs to be open and here is why
. If sealed when air enters the airbox it just sits there and heats up by the surrounding plastic (feel the bottom of you airbox sometime after a drive or track session its screaming hot because the fan blows directly on it). The air temps can mildly heat up inside the box until it enters the intake if no flow is available. Yes when the car is sitting still and engine running it would make sence to have those sealed. If air can move through the box if even ever so slow then there is a constant stream of cool air replenishing. I solved the heat on the bottom of the airbox by riviting a layer of heat shielding to it. Keeps the box very cool even when sitting still and having the fan blowing on it.
So is there even 1 cent of performance increase from it? Who knows but I liked the theory behind it
