Another Tech Question...
Rich Carlson
N. Richland Hills, Tx
Yes, but I need to know if you are checking the voltage by back probing the connector or you are checking the open circuit voltage with the connector disconnected. The voltage on the green wire with the key on only, will give you a baro read or in other words the altitude you are at. But not sure of your location. Do you have a problem?
naimsito
