Any Gen I s with head work done?
Bad_Byte
Corpus Christi Tx
Just did mine and before heads 420 rwhp, after heads 480 rwhp. I already had rockers, headers and smooth tubes with K&Ns. So for the price it was probably not worth it IMHO.
I needed heads any way, but that's another story. Since I needed heads and a new gasket, it was becomming apparent, for me it was a matter of do or don't drive.
Bottom line is 480 rwhp on a gen 1 is kinda nice. Now all I need is a turbo.
dblankenbaker
Scottsdale, AZ
Bad_Byte, put the orange stock Gen II injectors on your car and dyno again. You will be pleasantly surprised.
Bad_Byte
Corpus Christi Tx
Funny you mention that, I've been contemplating it but have not had time to research. I almost purchased a set off E-Bay the other day but backed off pending my research as to benefit and necessity. I'm running right at 12.8 - 13.0 AFR but I really don't know what my duty cycle is so I'm not sure if I'm close to that 80% range.
So you're suggesting a set of stock Gen II injectors will benefit me in the HP area? How so, if I'm already running the AFR I am?
dblankenbaker
Scottsdale, AZ
Okay, maybe not... I'm surprised your AFR isn't leaner. My Gen-1 AFR is right there with the rockers but w/o the headwork. I have one friend who had Gen 1 heads done and he was disappointed. The dyno operator told him his AF was a "little" on the lean side. He borrowed a set of Gen-2 injectors and picked up "tons" of torque and 25 HP (over 500).
If I were you, I would at least borrow some injectors and try it. I think Sean Roe has some takeoffs and would probably loan them out, and give you a good deal if they help you.
Bad_Byte
Corpus Christi Tx
Yeah, I forgot to mention I have an aeromotive fuel boost pump setup. It allows me to adjust the pressure. sneeky huh...
SSNAKE
Belleville, IL US
I have exact mods as bad byte and identical results. I did the mods only because I needed the gaskets. It was expensive before the exchange programe has begun with others. I think it was like $3500 for the heads. The gen II injectors are guaranteed needed to complete your package BAD BYTE. It was the missing link for me.
BarryLB
