Best Spring Compressor to remove springs from shocks without damage?
bwhitmore
Sacramento, CA
And don't say that dumb hydraulic one off of ebay. That thing doesn't fit in between the coils. I want something that is tight and neat, can be manual (that is turned by ratchet if necessary). But I am powdercoating my springs and refinishing the shocks so I don't want to ruin the finish...
Dave's Big Brakes
San Diego Ca USA
I,ve got the harbor frt one, it's not great but works ok. I've tried everything else with no luck,problem is the spacing between the coils. Real tuff to deal with. I even went to many shops, and couldn't anything that worked. Good luck
B
bwhitmore
Sacramento, CA
Dave,
So the Harbor Freights fit? I can probably wrap the coils in layers of tape to protect them. But they have to clear the shocks since I can't really wrap those without the spring off.
Qualitywires.com
Louisville, KY
nope...remember that you told me to hold off because the vendor ran out of them and he refuned yor money. I will get you one if you want.
The Harbor Freight type works...just FOLLOW the directions and use anti-seize on the threads...and, at $9.00 a set, buy a couple of sets, and throw them away after usage.
Mando9595
