Body Screw Size
mdurbahn
Denver CO
I need to get some additional body screws that hold on the exhaust sill covers and the front bumper/fascia (screw into frame with big fender washer head on them) What size are these supposed to be? I want to try to get some at the hardware store tomorrow and don't have the ability to pull any out to match with. Does anyone know what ones fit?
Thanks Guys.
dave6666
The fascia screws are a Mopar item - see your local Dodge dealer and tell them that you want a 20% discount offered to...
Oh. I see you're not a VCA member.
Maybe it will work. :D
The sill screws are not a dealer item. See Home Depot or do the rivet-nut conversion.
01ACR/VIPER
ORLANDO
Ace hardware---ss #10 hex head sheet metal screws x3/4"L and ss fender washers.They have both of them,I just did all mine new.:2tu:
jdeft1
Metropolis
There's a post in the how-to section about converting the sheet metal screws to the rivit-nuts / bolts ...I can't see it either anymore. It's highly recomended for the underside of the sills as the sharp screws can work out and go straight into those high dollar rear tires!! It's easy to do and works well so far for me.
jdeft1
Metropolis
A rivit-nut is like a female threaded "pop" rivit. You insert it into the hole and expand it with a setting tool. Now you just use the proper sized ss bolt and tighten it up.
