Don't go so slow! O.K. , new plugs might help a bit , but it is the nature of the beast to surge a bit. Tell him to work the clutch pedal while putting around.
PErhaps a throttle cable sync... excellent instructions for performing this exist on the board, I think perhaps in Illustrated Upgrades section? If not there, do a search.
But as was said before, tis the nature of the beast.
Don't know for sure if Gen II's had problem too. But yes, drivers side should move first, just very slightly. It's the side that tells the computer what to do.
Jason, you adjust the newer ones by tightening, loosening screw on passenger side throttle body linkage. As you screw the bolt in it will cause TB to open up sooner/later and vice versa. Remember, the driver side only leads by a nats a$$
