can you run a 28" rear tire without clearance issues?
darkostoj
Detroit
I want to fit some taller DR's in the rear since i really like the way they look and want some better hooking at the strip.
I am looking at these toyo proxes TQ and heard great things about them. They are a 345/40/17 size (27.7" tall, 13.7" wide) and the best thing is they are only $170 each! I was wondering if anyone knows if I'll have clearance issues anywhere. I've done a search but havent come up with much info
TOYO Proxes TQ P345 40R17 LL @ TiresDirect.Net
RobZilla
Jacksonville, FL USA
Measure from the top of your rim to the fender well. If you have an inch or so gap, you'll prob be okay. You gotta remember on launch the rear is gonna fall as the front rises.
:usa:
Ray W
Fort Lauderdale,FL USA
Maybe e-mail Doug Levin. I can't remember if it is 28" or 28.5" that won't fit because of the inner fenderwell in front of the tire. I think you can go up to 29" with the inner fender removed.
1TONY1
Dalton Ga. (Chatt. Tn.)
28" Mickey Thompson ET street will rub at the upper front and that's even after removing some frame metal at the front of the lower wheel well. It might work without removing the metal but after it rubbed through the plastic and got to the metal it would start cutting the tire. I haven't done them, but there are some alignment tricks that can be done to move the rear wheel back....that might get what you need.
JayW1
Windermere, FL
It must depend on the car. I have a 2000 GTS at the stock ride height that I run 28" PS2's on with no rubbing at all. The tires are very close to the lower front wheel well but will move up and down with no issues.:dunno:
1TONY1
Ah...tire growth. I'm not sure how DR's will do but my ET street will grow at high speeds. Dr would probably be between a true radial and a slick or ET street.
D
darkostoj
Detroit
man i wish i could find someone who has these toyo DR's mounted. they spec out at 27.7...so maybe they will just get by with a hair of clearance and no rubbing
fe4snake
Florida
I think that spec is not right. I just did the calculation for you, just follow the math this works for all tires.
  • Diameter = 345 mm / 25.4 mm (conversation) x 0.30 (aspaect ratio) x 2 (sidewalls) + 17 in (wheel diameter) = 25.15 in. not 27.7 in
  • Diameter = 345 mm / 25.4 mm (conversation) x 0.30 (aspaect ratio) x 2 (sidewalls) + 18 in (wheel diameter) = 26.15 in.
  • Diameter = 345 mm / 25.4 mm (conversation) x 0.30 (aspaect ratio) x 2 (sidewalls) + 18 in (wheel diameter) = 27.15 in. (stock tire for all Gen III & IV)
  • Diameter = 345 mm / 25.4 mm (conversation) x 0.30 (aspaect ratio) x 2 (sidewalls) + 20 in (wheel diameter) = 28.15 in.
That has to be a missprint, beacause it does not make any sense. :drive:
D
darkostoj
Detroit
if you go here it shows 27.9
Metric To Inches Tire Size Conversion
so i havent thought about this, but what do you guys think would happen with the stock gearing and a 28" tire? Would that just not be a good setup at all?
1TONY1
I would go with the manufacturers specs rather than some aspect ratio calculator :)
PROXES TQ | Toyo Tires
That 27.7 spec is on a 12" whell. On a 13" wheel it will probably get shorter.
I just got my Hoosier drag radials yesterday and they are ssssssssssssssssssssssoft !!!
SKY1960
