Catch can question??
MAVPR
Scotland
Hello, I have recently installed a Reo supercharger to my 97 GTS and am about to add a catch can to the setup.
My question is can I run the two crankcase breathers that are already there straight to the catch can and block off the hole at the intake?
Or is it somehow important that the intake is still connected in some way to the new setup? I did a search and found a "how to" that says block off the intake but I just wanted to double check with everyone.
Thanks for any help!
VPRPWRD
Orwigsburg, PA
Will the catch can have a breather on it? If you put the crankcase pressure into a sealed can it will push that pressure out where ever it can. As long as you have the breather on the catch can I see no issues running it this way.
M
MAVPR
Scotland
Yes the catch can will have a breather on it. Thanks for the reply!
BlackSnake99
Northern Virginia
I messed around with using the OE valve cover outlets and found it to be insufficient for an FI set up. I decided to do it right and went with the breather from A&C Performance.
VPRPWRD
Orwigsburg, PA
That is a sweet set up!
zeeshan_k24
