mike & juli
I understand you guys are attempting humor, but if you keep it up I'm actually going to make a post on how to properly start the Viper.![]()
THERE ya go!!!!
![headbang :headbang: :headbang:](/vca/styles/default/xenforo/smilies/headbang.gif)
![nono :nono: :nono:](/vca/styles/default/xenforo/smilies/nono.gif)
![omg :omg: :omg:](/vca/styles/default/xenforo/smilies/omg.gif)
THERE ya go!!!!Now you see how things work around here (most of the time!)...you will ALWAYS get beef (beefcake?!!!! JULI..stop it!
)...when you post ANYTHING on here! GOOD for you for keeping your humor! (It's needed here, but NOT anything like the ALLEY...DON'T GO THERE
) ~juli
I do get it, and I understand how it works. The new guy made a post that was relatively simple, but yet will still help some people, and the experienced members took the time to rag on it instead of saying something productive, or nothing at all. It's all good - I see it all the same on my forum.
While it is all fun and games, it somewhat creates a divide in the community (which I have seen already in just a week of being here), and changes the tone of the forums a bit and makes some poeple get defensive and confrontational.
But, what do I know. It's not like I do this for a living.![]()
- Anthony
- Anthony
Anthony, one of the great features of this site is the Ignore List...its just a wonderful thing. Keep the How-To's coming...it doesn't matter how obvious they may be to some people but the How-To's do appeal to a broad majority here. Not sure if you can see the Illustrated Upgrades section but we certainly encourage members to post their how-to's and keep that library growing.
- Anthony
Anthony, could you please post this over at viperalley as some members there don't visit this site.
They will appreciate your post.
Now Mike..............................................this is what I was afraid of...but not from you.~juli
Personally, I prefer using a simple hand jack at the jack point behind the driver's front tire to get the car up in the air (Blocks under the tire so it doesn't drop on me).
Thanks for this advice. i have 5 jacks in my garage, two sets of ramps and could not figure out how to get under this car. Ended up driving on some scrap 2x6 which gave me enough height to get a jack on each side under the jack point. Saved me a 3 hour drive to go pick up a low profile jack. Thanks
Thanks for the write up.
Right then, On a more serious note, I have read the workshop manual on how to change the oil, but I have a question....
Do any of you guys use flushing oil additive prior to changing the old oil? If so how many cans do you use? Or is this not recommended?
Also wondering, The recommended Mobil 1 for a 2000 gts is 10-30w.
This is very hard to get hold of in the UK, so if I was to use the latest Mobil 1, 0-40w would that be ok?
Mark.
Or you could just put the 2x6 infront of the ramp and then drive up on it, and then onto the ramp.![]()
Much easier than having to use a jack and jackstands.
Mark.
And she sounds a lot better now. I don't think she enjoyed being on the same oil for two years, although it was only 2500 miles.
Anyway, the tools you'll need:
3/8" Torque Wrench
Funnel
Oil Filter Strap Wrench
15-Quart Drain Pan
16mm Socket/16mm Box Wrench
Brake Cleaner
Shop/Paper Towels
Ramps
As we all know, the Viper is too low to get onto most ramps. I have a set of Blitz Rhino Ramps and they are just a bit too tall to get the Viper on without any help. I was going to build a "step" up to the ramp with two 2"x10"x16" pieces of wood, but this worked just fine:
I used some permanented double sided tape on the bottom of the wood where it touches the ramp and the ground, and the piece stayed in place just fine. I will eventually angle the ends of the wood so it will lay flat, but this works if you need something quick.
Once in the air, remove the oil filler cap:
Mobil1 - yuck!
Get under the car and put down some newspaper so that when some oil drops on the ground, you won't get yelled at by your significant other. Put the 15 quart drain pan under the drain plug and get your 16mm box wrench and loosen the plug. Then with your arm perpendicular to the ground, remove the plug by hand:
In the middle of the drain I got an oil collection kit and took a sample, and I'll send that off tomorrow to get analyzed so we can see how the Mobil1 stood up.
Once the oil starts to trickle out of the pan, put the plug back in and finger tighten it. Then go over to the oil filter:
This was on there way too tight for me to remove by hand, so I got a strap wrench and loosened it. Unscrew it a bit and thne let the oil drain out of it while it's still attached to the car. Once this stops, continue unscrewing the filter and then let the rest of the oil drain from the oil filter post. I'd say about half a quart came out.
Then get your new filter and put some oil on the rubber gasket so it will remove easily. Get it on there and then hand tighten it - I believe the instructions on the filter say get it tight and then give it another turn. An oil filter doesn't have to be extremely tight, contrary to what a lot of people think. Just make sure it is snug and you'll be good.
When you remove the oil filter, you've changed the pressure in the system, so some more oil will go back into the oil pan. Unscrew the drain plug and watch as about another half a quart coems out. Since the car is on ramps, and the oil drain plug isn't on the back of the oil pan, there is still going to be some in the system.
This drain plug has a rubber washer built into it, which is why it doesn't need to ever be replaced. I'm not sure what the actual torque is for the drain plug, but most are about 20-25 ft/lbs, so I torqued it to 25 with my torque wrench.
Then all you need to do is add about 9 quarts of your favorite oil (I used Valvoline SynPower 10w30) and then start the car, check for leaks, and then remove it from the ramps. Let it run for a few minutes, then let it sit for about five minutes, and then check the oil level. Mine was right where it was supposed to be.
Anyway, hope this helps some of you if you are planning on changing your oil but don't know what's involved. It is a very, very straight forward process. Everything is right infront of your face, and there is plenty of room to work. You don't have to remove any splash guards or underbody panels to do this. I'd say it took only about 45 minutes to do, and most of that was waiting for the oil to drain out.
- Anthony
