Check Engine Light ... SCT Scanner or Purchase OBD2 Code Reader? ---
alwayscode390
STL
I let the car sit for 2 days ... got in it , noticed it had a flat tire ... drove it 1 mile up to put air in the tire and the check engine light came on.
Would the ABS sensors see the difference in tire diameter from left to right rear tire and throw a code?
I have the 9550 SCT scanner, but it hasnt been used before ( cant find anyone with the dongle ) ... will it still allow me to read and clear codes?
If not, will ANY obd2 code reader work , or do you have to use a specific brand for our cars (what brand) ?
I put air in the tire, if that was the code, will it reset itself after a certain amount of miles? I only drove it about 5 miles after putting the air in it.
The code didnt reset after I shut the car off and restarted it.
2001 GTS
MTGTS
Orlando, Fl
You should be able to plug the SCT into the OBD port to read and clear the codes
DrumrBoy
GA
What MT said. Also, if you can't find the right connector easily, pick up an OBDII reader at O'Reilly's or Advance, they're only $39 and will help you figure out what the code you threw means.
A
alwayscode390
STL
OK thanks guys, I wasnt sure if the SCT had to be "used" or "unlocked" first, since its the version with NOTHING installed tune wise from the factory. ---
Dom426h
DE
no, thats what you have an ABS light for.
yes
any will work. Including the ones that Autozone lets you use in the parkinglot for free
depends on the code. If it is a self clearing code then it will take a few complete drive cycles before clearing.
no surprise there
goodluck, and let us know what code you pull
