OBD2 scanner
mhpearlman
2014 GTS with 6k miles (what I feel to be in perfect condition) and the check engine light just came on. Any suggestions for a scanner made for a viper? or all scanners built the same? thanks
I would suggest that you get an inexpensive scan tool from Harbor Freight, Northern Tool, etc. Just be sure that is OBD II, CAN bus, reads and clears codes. They are $40.00 to $60.00.
I carry one in all cars...note just to clear the codes, but by doing so, one can get the car out of limp mode (at least on a temporary basis).
Remember: clearing codes is not a cure for the issue. Always record any codes that you plan to clear.
Dave1968
I say spend a few bucks, get a good one as it will show you a lot more. Autel makes great units. You will have it for life and can use it on any vehicle with the OBD2 port. Have Fun!
RandyM
Seabrook, Texas
I suggest when you look for one, get one that will also diagnose ABS systems, some of the less expensive ones will not.
InTheZoneAC
obdlink mx+, wireless unit. Also supports other apps besides their own if you want to use another app.
I have a Xtool D9 and its Bidirectional. I love the Bidirectional feature. Does pretty much everything under the Sun including OBD I.
Comes with 3 years of free updates as well.
Jack B
NE Ohio
Along the sme lines, I have a Witech that I am going to sell. This is the same format the dealers use. You can extract data that the typiocal OBD scanner cannot see. As an example you can log PIDs such as knock sensors if you are tuning.
prodiver
Apache Junction AZ
I have been looking for a good one for an 09 and I have not found 1 that can reprogram the Throttle Position Sensors, The Accelerator Pedal Position Sensor, The Crank Position Sensor or the Tire Pressure Monitor. I have made a lot of inquires about even some expensive ones and they all said it has to be done by the dealer.
XXL-MX5
