I previously ran the Spec Clutch 3i and just installed their new 3+, is anyone running the 3+ and if so how has it held up?
When the 3i had to be changed, Spec had stooped manufacturing that specific model and had not started the 3+, I needed a clutch and a Centerforce was available, that is what I ended up with. It worked fine till it was used with the nitrous, one session with nitrous and the car wouldn't shift at all. Basically a long burn-out and hard launch and the disk swelled and wouldn't allow the car to shift. The Centerforce is non-metallic, but, it still burned the flywheel to a point where it was slightly warped.
