I think this may be an air-in-the-system problem that burping would correct but since its never happened to me before, I figured I'd consult the experts.
Ran the car at a track event this weekend....everything fine. Temp gauge stayed right where it always does, at the rightmost of the three lines at 190.
OK, now I drive home in fifth gear at 70 and the thing starts moving quickly to 245.....a couple of times it seemed like the thermostat opened and brough the temp back to 190 but it wouldn't stay there so I pulled over, let it cool and noticed the overflow reservior was empty.
Filled the overflow res, started it up and the overflow reservoir emptied into the raditaor. Filled it up two more times and now everything seems fine. Car runs right at the third 190 line.
So, I'm wondering if this is:
(1) simply a low-on-coolant issue
(2) air in the system that needed to be burped out
(3) sticking thermostat
If its (1), I'm amazed that the temp stayed OK on the track...last session was 30 minutes before the ride home. I would figure running under alot of throttle between 3 and 5 grand would create more heat than a leisurely cruise down the highway (in 60 degree air).
If its (2) I'm surprised that adding fluid without burping would solve the problem. Wouldn't the air still be in there?
If its (3) maybe the addition of more lubricating ehtylene glycol loosened the thremo up enough for it to work for a while...but I may have to change it out again soon. Thermostst was replaced about a year ago - so its not the original one (hence not 10 years old)
....or perhaps it #4, something I'm not thinking of.
Thoughts/advice welcome
