Cooling system hoses
wormdoggy
Toronto, Ontario
I'm in the process of installing the new headers that I got and I was wondering if anyone has wrapped the cooling system hose with refractory material for heat issues. Seems kinda close to the headers ?
Patrick
KaiPL
Salt Lake City
Just about every hose and line in my engine compartment is wrapped with reflective materials.
viperbilliam
Richland, WA
You might want to follow the factory design and use the manifold/header shields that were provided. If the factory ones don't fit, I believe Daniel Cragin at DC Performance, a vendor here, has better ones for fitting aftermarket headers (not cheap, though!).
W
wormdoggy
Toronto, Ontario
Actually I am re-installing the heat sheilds on the new headers and I am also planning to heat gun the stock manifold and then the bellanger headers after install to see the difference in temperature. I will post the results once completed.
Any advise on where to point the beam from the heat gun for best results?
I will also have pictures of the install as we go through it for future users.
As for the refractory material. I am in the insulation business and I just found out I can get refractory ceramic blanket rolls in two inch strips. I will use that which is good upto 1200 degrees. We usually use the ceramic blanket rolls on generator exhausts or high temp applications. A little over kill but better safe then sorry.
Patrick
zeeshan_k24
