Damn ACR wont let me in
01ACR/VIPER
ORLANDO
The passengers side that is.Sometimes the door opens sometimes....NOTHING.I took the hinge cover off and went through the wiring harness pulling and trying to find a broken wire....found none.Does any one have a clue what could be causing intermmitent operation?Or exactly what color wire is the one from the door to body?I will cut and splice a new one if i could find it.Thanks in advance fellow viper peeps.:2tu:
dave6666
Check the switch?
Also, broken wire can mean broken conductor with intact insulation. Pulling won't detect that easily.
BTW, what year?
Just went through the wiring diagrams for my '01 and there are 4 pages worth. A little more complicated than the windows or speakers. Do you not have a manual?
plumcrazy
ALL OVER
compressed air around the button for a bit, then a quick shot of wd40. as per the wizard 3 years ago for me...
01ACR/VIPER
01ACR/VIPER
ORLANDO
Check the switch?
BTW, what year?
Hey Dave,all i can say about the switch is that i can hear it clicking everytime i push the knob.It is a small micro-switch in there and they USUALLY work if you can hear it clicking (we use to use them alot on our machinery controls).As far as wires go...when i did pull on ea.one i pulled ******* ea.to see if it would stretch meaning a broke wire not the insulation.I do have the manual but to be honest....i am not an electrical guy at all:dunno:it all looks like a bad road map to me.
Oh yea,mine is a 01 (01ACR/VIPER:D)
01ACR/VIPER
01ACR/VIPER
ORLANDO
Was your fix for a STICKING BUTTON?I had that problem on the drivers side:rolaugh:That fix worked for the sticking for sure.:2tu:
plumcrazy
ALL OVER
it wasnt really sticking as much as not quite pushing down far enough and letting the switch do its job.
try it, ya got NOTHING to lose
dave6666
Check out this thread I did on a "good" window switch. I would take "clicks, must work," with a grain of salt.
http://forums.viperclub.org/2485712-post1.html
dave6666
12V fused to exterior door switch - red
12V from exterior door switch to Entry Module - orange/black
Latch motor from Entry Module - gray/red & gray/yellow
So am I SMART now?!?
