Does it ever stop..............More modding...
VIPER BAZ UK
ENGLAND
OK OK Its almost stock LOL.......
Been reading up and looks like from the under side is easier..
Will keep you posted....
red98RT10
Greenville, MS
If you have a way to drop the tranny then it is easier to install that way. However, I just installed one of those from the top....so if you have any questions, feel free to PM me.
Neil - UK
ENGLAND
stock just as it left the factory ;)
youll soon have enough OE parts to build another viper !
hope its a gen3 shifter :)
V
VIPER BAZ UK
ENGLAND
Sorry Neil Gen2 sitting gathering dust and got it at cost...
Red98rt10
Mate has a work shop where he preps rally cars so should be easy from the underside on his lift..
Didnt fancy the drilling holes in the trans tunnel..
RoadiJeff
Wildwood, MO
I installed one of these a few weeks ago from the bottom with it on jackstands. Not much fun but if you have access to a lift I can see how it would go a lot easier. Some air tools would help too.
A few things that may not be written down in the how-to but you don't want to forget. First, shift it into neutral before removing the old unit. It makes it easier to line things up when you put the new one in and don't have a direct line of sight. Second, grease the ball on the new shifter before installing so you don't have bare metal to metal rubbing.
Have fun and good luck.
G
grcforce327
Guest
I think it's quick and easy from the top!Need a rivot gun and a couple rubber plugs!You will really like the difference the shifter makes! :2tu:
zeeshan_k24
