Door problem
nismobrown
wales, GB
can anyone identify the following problem.
my 99 gts passenger door started to pop open by itself only when unlocked/
parked or when driven up to the speed where the car locks itself.
this problem changed within a week and now the car can not be opened at all from the outside switch but still unlocks itself but far less than previous .
the inside handle works fine and the doors lock as they should using the remote.
thanks.
2000GTS
Miami, FL
Try spraying some WD40 into the door popper button. Then work the button a few tmes. Sometimes the switch gets stuck back there.
Bill
Joel
Ireland
I had exactly the same problem on the Skunk. A new microswitch in the door button fixed the problem.
N
nismobrown
wales, GB
I was hoping that the wd40 would work but unfortunately has made no difference so it looks like a new switch is the only answer.
does anyone know the approx price for the switch?
thanks.
BarryLB
