DRBIII Fuel Injector Kill Test: Pass / Fail is... ???
Tom and Vipers
Jeannette, PA 15644
Did the test and from what I can gather, you have to visually average the fluctuating rpms as you select the injector to kill/test.
I had some cylinders spike below 900 with an average in "low 900's" while other injectors spiked above 1000 with an average in the "mid to high" 900's.
Obviously, there is some variation that I would not hope to see, but what is the Pass / Fail for this?
I suspect I should have the injectors flowed, sprayed, and cleaned which leads to the QUESTION: Where? EDIT: Actually tons of videos DIY with injector removed. Of course having the side feed injectors is a RPITA.
