Drivers Window Won't Go Down !
Gerald
Near Tampa Bay
Re: Drivers Window Won\'t Go Down !
Your molding came off and fell in and jammed. It should be the pc that is between the rear of your window and the door pillar. See if you can get it out somehow and you can EASILY use adhesive (3M from local Home Hardwarew store) to put back on.
If it's down in there, tough part will be getting it out.
Gerald
shibbydude
