FastZilla
I figure I would start a thread on this issue I'm having. At 59 miles my CEL came on and the ETC light began flashing - the ETC light is: ")" lightening bolt between "(" in the gauge opening below the fuel gauge. The car went into "limp home" mode - you are limited to about 2000-2200 rpm and have what feels like 1/10 of the throttle. Yes in 6th you can cover a lot of ground (comfortably cruise at 80) but you aren't getting there quickly. I have had the dealer and Tere (thank you!!!) scan the OBDII and come up with:
P0335 - Crankshaft Position Sensor
P0337 - CPS Low Frequency...something.
The ETC light clears overnight or after sitting and cooling down. I get between 15-75 miles before the ETC comes on and I'm back in "limp"
I have removed, cleaned and reseated the TPS and MAF connectors. I think I have done the same for the CPS however I do not know that what connector I have been messing with is actually the CPS.
I'm looking for any suggestions/help. I've got an `09 ACR with the performance of a U-Haul. Presently I am "officially" in the poser ranks with a lot of "show" and no "go".
Thanks in advance!!!
