JohnnyBravo
Brought to you by Underground Racing:
"Here are some pictures of our 08 TT Viper. This is the first one known of that is running with a power adder and full control over the cam and drive by wire throttle bodies. I must say that we are very impressed with the 08 platform after it got the TT treatment with the full built stroker engine. Power on pump gas heat soaked is 1000 RW with around 11 psi. 19 psi we made close to 1300 heat soaked. The system also has the Underground Racing/John Reed Motec system onboard! John did a great job on the Motec set up! The TT 08 Viper drives just as it did stock! More information will be released soon."
In a good way.
