Flats, flats and more flats
CHAOS
Vero Beach Florida
Do all Vipers have the problem of picking up sharp objects in the tires or am I just "lucky"? I have replaced two back tires, one front tire and right now saw what looks like a freaking rail road spike in my front tire. I am just glad the tires are not really expensive:mad:
eucharistos
Houston
these things come in 3's
looks like you are done for awhile,.........
unless you need to finish out the 2nd 3 :omg:
V
Venomiss
Guest
Be happy you can drive your Viper with the nice weather in Florida?
Ohhh sand, beach, and sun. Sounds pretty good about now.
PhoenixGTS
Phoenix Arizona
One time I was working on my GTS (I think I was installing coilover shocks) and went out for a test drive after I was done. I heard something hit the belly pan of the car then make some other noises. I knew right away what it was. Sure enough I pulled over and when I walked back found the handle from the miniature ice pick I had left sitting in the channel on the top of the upper control arm (I had used it as a tool during the project). Sure enough the pointy steel part was stuck in the rear tire.
