Fluid leak on a 1993
ohiotj
Marietta ohio
I have noticed a clear fluid being left on my garage floor. It seems to be coming from the dead center on the engine but I have not jacked up the car to confirm where it is seeping from. It seems to evaporate but when I rub it between my fingers it does feel like it is not water. I don't have ac. Does this sound like coolant? As far as I know the car has all the original gaskets. Also I bought it three weeks ago and the car had 11k on it and I have put over 500 on it plus a track day. Thanks for any ideas.
Ryan.
OEM P/S fluid is clear...look at racl, lines, etc. SMALL amounts of some oils MAY appear clear...lift car, check oil pan, timing chain gasket cover, valve covers, etc.
Condensation from A/C (if so equipped) tends to drip to right side.
BEWARE...SOME hot climate cars have only water as coolant.
Good hunting.
Sainthitch
more then likely the original paper gaskets that are causing the issue.
Drock187
