FLUIDYNE Racing Radiator 97-98 Viper
ruckdr
Renton, WA USA
Do a search; much discussion about radiators on the forum. I have the Ron Davis from JonB at Parts Rack. It was a drop in with no Modifications necessary (Gen1 with upgraded Gen2 fan on my car). Installed 180 deg. thermostat, and temperature very seldom gets to where fan comes on - what is that about 210 deg. I run at the track on HOT days ant it stays cool.
JonB can give you all the specifics about the radiator and why it is so good.
Later,
REDSLED
Bakersfield, CA USA
I have had both the Ron Davis and Fluidyne and they are pretty much the same performance wise. The problem is not the radiator (the stock one is sufficient) it is the air flow that is getting to them. The front fascia kit that Sean Roe sells will lower your radiator temps much more than upgrading the radiator. The Roe Kit will fix the air flow problem so you can keep your stock radiator in place.
ruckdr
Renton, WA USA
REDSLED,
You said in part:
Agree, the stock one is sufficient, unless it is plugged, or not flowing as mine was, which was 10 years old, and low miles. Using a IR temp thermometer, showed sporatic temperatures across the radiator. My temp would get to the right mark before the red, and past almost to the red mark. In traffic, just sitting, it would climb to up there also. Replaced radiator (Ron Davis) and went to 180 deg. thermostat, and all is fixed (1 year now). Now, it's like look at the temp gauge once, and forget it - well you know what I mean, it is no longer a concern.
Later,
ViperJames
NY/CT
Wow this is really great information. Thanks for sharing.
98viperGTS
South Carolina
That is the reason that I am asking. Right now if I am driving the temp gauge is about center when I come to a stop it starts to rise to the mark that is before the redline mark but comes back down. Then when I take off it starts to climb back up to the mark before the redline mark and comes back down when cruising. The only think that I worry about is the stop and go traffic keeps it moving between center and the mark before redline.
RobZ
Tucson, AZ USA
Stock is not fine for track driving. My stock GTS runs hot after about 6 or 7 laps in New Mexico.
Viperless
MN
SPAL make a pulse width modulated fan controller that has programmable on & off temps. It uses the factory coolant temp sensor. It will vary the speed of the fan based on engine temperature which is supposed to help maintain a more consistent temp. So in theory, you shouldn't see the large swings in temp. Has anyone tried one?
SPAL Fan Controller
REDSLED
Bakersfield, CA USA
Dave's Big Brakes
San Diego Ca USA
What Redsled said:omg: I have the lower airbox also:D it reduces temp big time:eater: BUT takes some really BIG Ones:rolaugh: to cut the hole in the lower fascia:omg: One of the best mods for the money:usa:
Big Brake Dave:drive:
Disturbed
Orlando, FL
My car would get a bit warm after I built the motor. So I put in a RD radiator and 180 T-stat. Now it's fine. Even when it's 95+ outside and I do a 2mile blast from 80-180 and hold at 180 for approx 3/4 to 1mi. The temp NEVER gets above 195-200.
Maybe I need to try that roe kit as well. If I had the balls and enough tarmac, bet I could break 200mph.
Slntnoze82
