Front wheel bearings ...
eliems
Vancouver BC
Looks like the front wheel bearings are the reason for my brake pedal variation, (the wheel leans on left turns pushing the pad in and then the pedal goes deeper).
Question ... I have a friend who has a lift and does "back yard mechanic" work for me at times on my other vehicles. Is this job straight forward as he thinks it will be or should I pay 4 times as much and have the Chysler Dealer do it? He is a good mechanic.
xlrashn
Marion, Iowa
It is pretty straight forward. You will probably need some boards to drive up on to get the hoist arms under the Viper though.
bushido
Monterey,CA
Like the others said. It is very straight forward. I ordered 2 front bearings from Chuck Tator and changed them out myself. It took me around 1 hour to do both sides. With that being said, I heard that the rear ones are a b_tch..
Tom Sessions
Hampstead,NC.
So once a year you should check you hub nuts on the front and rear. Torque them to 300lbs/ft. You wont find that spec in the service manuel. the first time you do it you will be surprised how much it takes to tighten them.
AZTVR
Chandler AZ
300 lbs/ft !! :omg:
white out
The Mitten
You would hate to work on an H1's suspension. . .:omg:
Nick
bluesrt
put some new rotors on it to to get rid of the vibration
potterb4
