Gearing Question........
VIPER BAZ UK
ENGLAND
Ordered the new 5th 6th gears....
.80 / .63 Can some one tell me or have a link to a chart that would now tell me my new RPMs at 80mph ect ect from my oe 5th and 6th..
Many thanks
PhoenixGTS
Phoenix Arizona
Found a good one with google. Here is a link:
Second Strike Gearing Calculator
[EDIT] dang just noticed you cannot insert your own ratios on that one. I can't find the one I used to determined that with GenII-height rear tires, 3.55 rear gears and the .64:1 6th my car would theoretically be going right at 200 mph @ 6,200 in 6th. Search through old posts and you will find one.
FE 065
MI
rpm x td
---------- = MPH
gr x 336
td = tire diameter
gr = overall gear ratio (axle gear x trans ratio)
336 = constant
and variations for gr, td, rpm
Jack B
NE Ohio
I could never get the Unitrax calculator to hit reality, there has been that discussion before.
An additional heads-up, the oem tire is 26", but, if you are using a 26" bias ply slick it will grow at least 1" at the end of the quarter.
VIPER BAZ UK
ENGLAND
Got the OE specs..
But cant find a chart/conversion table to work out with .80 / .63 5th and 6th
GearRatioOverall Ratio(Rpm)Mph1st2.66:18.17:1(6000) 562nd1.78:15.46:1(6000) 833rd1.30:13.99:1(6000) 1144th1.00:13.07:1(6000) 1485th0.74:12.27:1est (4950) 1656th0.50:11.54:1est(3360) 165
