I have explained this several times now. The reason why I chose the "other" dyno place is because they dynoed my car before. I wanted to use the same dyno to eliminate any dyno-to-dyno difference.
my bad must have missed that part
The car is very RICH at 5000 RPM, not lean....
Have you noticed this problem being heat related in any way? Runs good when air temps are cool, but have the problem when things heat up?I've tuned over a dozen of these VECII cars and for some reason they all have that V somewhere up after 5k RPM... some closer to 5600, while others closer to 5200 or 5400. Very strange.
I wonder if there is a way to get rid of this? I can _move_ it by taking timing out... but in many cases, that isn't what needs to be done...
JD
In Atlanta, it is always hot.![]()
Ken
The injector connectors were one of the 20 or so changes I made trying to alleviate the breaking up. JD has tuned my car as well and like he said, on mine, timing seemed to help some but never allowed us to go past 5400 rpms with some sputtering prior to that as well.
I am "now" doing some mechanical changes trying to see if that is the issue as I have troubleshooted every conceivable electrical avenue I can think of, but I think it is a moot point as there are too many other na cars out there having the same issue.
John
Anaconda - keep us posted.
