Hard to Start
SuperSaiks
Hi Guys
It takes a long time for my 96 GTS to finally start. I have tried turning the ignition key off and on several times to allow the fuel pump to turn off and on but still that doesn't work either any ideas? Fuel filter?, bad fuel pump,
Fuel regulator ?
Indy
Vancouver
You'll probably have to go through all potential culprits and eliminate them one by one. Could be ignition related, fuel, battery, electronics...Start with the easy ones, like spark plugs, check for error codes with an OBD2 reader, battery voltage. You can usually narrow down the problem like that, but it might take a bit of time and patience.
Good luck!
BarryLB
