Harland Sharp rockers?
XLR8
Mesa Arizona
Does anybody have any feedback on these rockers yet? Are they conected in sets of two or mounted like the Crowers? Are they able to turn and come off of the valve stem?
Schulmann
Canada
I have the H.S. rockers on my supercharged Viper.
They can't turn.
I had them for 10000mi.
No trouble. They are quite too.
However if you was building a heavy duty racer I would go with other type of rockers. But for most of Viper it is perfect.
LETHAL GTS
Winnipeg, MB
Connected in pairs like you mentioned. I'm glad I installed mine. Cheap improvement. If you saw the factory garbage (sorry you stockers)you wouldn't even think twice about installing them.
EllowViper
Valrico Florida
Re: Harland Sharp rockers..What about push rods???
Are different length push rods required with the HS rockers given the differrent ratio...or will the stock rods work just fine??
CANTDRIVE55
Texas
You should always check valvetrain geometry after a valvetrain mod, IMO.
Mark Hahn
Roy, WA
Any special advice on installing Harland & Sharp rockers as I just purchased a set. Thanks, MGH
zeeshan_k24
