Has anuyone used the roe racing Front Bumper Fascia Cooling Duct ?
PhoenixGTS
Phoenix Arizona
I remember a thread where Tom of 40mm caliper fame had a nice post about his copy of the Roe facia mod. Search function is your friend.
carl B
United Kingdom
Just fitted mine and not driven it as yet
Carl
Jack B
NE Ohio
AB:
I first installed the kit on my Gen1. I was getting unstable at 120 plus. The Gen1 has an issue with high pressure lifting the front due to the air being trapped under the dam. The kit solved the instability.
I don't believe the Gen2 has the same exact problem, however, the kit also has a plate further back that blocks the high pressure from forming behind the radiator. In practice the high pressure is relieved thru the front opening and the bottom/back plate stops high pressure from forming behind the radiator and reducing air flow thru the core. I can tell you that the underhood air temp will drop after the install.
Tom F&L GoR
Wappingers Falls
Ditto what Jack said about Gen 1. Look under the bumper of a '97 Intrepid and you will see that even Dodge does it on other cars.
Bluvenm97
AZ, USA
Anybody else try one of these? I'm thinking about getting one for my GTS, but I'm nervous about cutting my bumper :(
Schulmann
Canada
Very good upgrade. Strongly recommend it.
The under hood temperature drops a lot, espetially with a 180F thermostate.
No stability issue upto 160mph on my Viper.
I just installed an Autoforme splitter and it covers the hole. Now my viper runs about 10F warmer.
In addition this is the first time since I installed it, that my the Roe fan kit (Relay) has started the radiator fan. I thought that the kit was defective but in fact the cooling duct was too good.
In my opinion it is a great upgrade.
Yes it is tought to cut out the bumper but it worth.
This is something that I would do again if I had another Viper.
Bluvenm97
AZ, USA
Thanks for the input so far guys. Living out here in the AZ desert, I can use all the cooling help I can get! It was 113 here yesterday :eek:
PresidentEvil
