HELP ASAP Im STUCK.
Dimitrios
Queens, New York
ran car all day. came to my friends house. went out and started it up and it stalled after a sec or two. tried this three times and it stalled again. forth time i have it extra gas and it stalled again. i feel like the last start up i used all the gas in the lines and now it cranks but doesnt fire up. also the door was working from remote. now the alarm, or doors dont open nd have to use manual emergency release. all i did was pone the trunk and removed my top. did i trip a pump shut off switch maybe???please help s i am stranded about 20 mins from my home. ill be up and waiting for pointers. thanks
917 923 0625
VIPER BAZ UK
ENGLAND
If its the same as a 94 there is a relay with a fuse in it in the trunk,If you neal down and look straight ahead you should see it.....
Does fuel pump click as you turn on key but not hit start ??? Fuel pump relay CAN be a problem...can be hard to seat properly...remove it, and try again to reseat relay.
VIPER BAZ UK
ENGLAND
On my 94 i have two amps one in each corner it is in the middle on the back pannel check the fuse in the relay itself might of caught it takeing the top out..
Thats if they didnt change it on later years....
I pull the fuse out off mine when i leave the car for long periods of time....
D
Dimitrios
Queens, New York
yes the whine from fuel pump i heard.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
May need to try to reset the alarm. If I recall the procedure correctly, turn key to acc - off, acc - off, acc - off, acc - off, then may need to press both buttons on fob until horn beeps to reset??
Good Luck!
GR8_ASP
Agree with Rocket. If it starts and runs until you release the key the alarm is activated. You may need to reset the fobs.
Jeff Torrey
Plaistow, NH USA
Sounds to me like the alarm is set and the fuel is shut down. Disconnect the battery for 20 minutes and hook it back up. Reset FOB and try to start car. You may have a low battery too.
D
Dimitrios
Queens, New York
thanks for all your help guys. after stuck for 5 hours marc lublin called me and told me to disconnect the battery cable and i did. car started right up and everything is well again. thanks so much marc and everyone else.DK
zeeshan_k24
